If a 3 phase motor mounted externally is getting damp in it, but not enough to short it out completely, would it exhibit any symptoms, such running at a higher current, spinning slower, or not sucking as hard (motor used for extraction fan).
interesting point as this sounds about right. It's down from 120 on the guage to 70is it running the correct way?, it may still draw, but only about 60% of its suction
does it make a difference?Canoeboy said:You didnt say it was on an Inverter !!!
From my (bitter?) experience: Years ago we used to import kit from abroad. (Access equipment). They used SEW inverters with Bonfiglioli motors at the start. The motors were dying left right and centre and we'd replace with SEW.well aware of that, but as 99% of the available parameters were un-used in this instance, laptops were not necessary
defo not - been checked several timesSince there has been a fair bit of work done on this circuit, could it be running only in star instead of Delta? Not sure on your inverter connections so I could be talking rubbish, just thinking out load.
yep - motors run more efficiently in Delta, but in-rush current is roughly 6 times higher than running current, so Star is used to get motor running, then timed relay cuts in to convert to Delta after say 20 secondsIt has been converted from star delta to delta not sure how as I don't get to involved with motors.
I think you're in the clear as far as moisture goes, you could do a quick IR test to confirm if you need to convince the customer. The blocked filter theory is also easy to confirm, if you remove a filter or two and it has little effect on the run current or air volume then it's not the problem. My first thought was reverse rotation but also might be worth checking for mechanical obstructions such as a partially closed fire damper or a VDU that's got stuck. The high running current might point to incorrect drive setup.
How high is the run current and how much higher is it now compared to what it was?
What type of fan is it? (FC/BC centrif, axial, mixed flow...)
