Dimmable led's
sparky b
Jun 21, 2010
472
Hi all,
I think I already know the answer but is there a dimmable gu10 style lamp available anywhere??
B
Hi all,
B
i think the toshiba 8.5w led gu10s are dimmable and very good lamp IMO. Dimmable Halers will be available january i believe.
my wholesalers wilts have halers on the shelf and can order the toshibas in.
You need them for Part L compliance?
Thanks again wozz,
I only need them cause it's what the customer wants....
I'll give wilts a try today.
B
Thanks again wozz,
B
Thanks kme, but they're not usable with fire rated downlights...
Are all dimmable led's like that?
B
Having done some more research, it would seem that a minimum amount of lamps is needed to get them lit up. If I was to use the toshiba 8.5w lamps it would need at least 5 per dimmer switch.
Has anyone come across this or worked a way around it?
Also are all dimmable led's not suitable for use in fire rated downlights?
Many thanks,
B
