Dimmer problem or am I being DIM??
paulmichael
Oct 14, 2010
I've a lamp that has a standard plug and plugs into the mains. I wanted to put a dimmer on the light so I split the live and using a one way dimmer switch (remote control type) I connected it up but the dimmer switch now will only turn the light on and no other function. ie it won't DIM or knock the light off. I had thought it would merely work like a norm switch by joining up a broken circuit. Is this not the case??
Have you used the correct terminals?
Some dimmer switches have 3 terminals, and if you choose the wrong pair, they become switches instead of dimmers.
Has the light fitting got a dimable lamp?
If yes... is it within the wattage range for the dimmer?
Many dimmers have a Min & Max wattage...
Too low or Too high it woe work proper!
welcome to the maddest electric forum at this web address!
GuinnessGuinnessGuinnessGuinness
