Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Storage Heaters & Central Heating controls Forum
Dimplex Duoheat Heaters
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="PC Electrics" data-source="post: 121991" data-attributes="member: 650"><p>A suggestion:</p><p></p><p>Make the peak isolator a 20A DP key switch and the off peak a standard 20A DP switch.</p><p></p><p>It would be easy for any customer to confuse two identical isolators that are not labelled.</p></blockquote><p></p>
[QUOTE="PC Electrics, post: 121991, member: 650"] A suggestion: Make the peak isolator a 20A DP key switch and the off peak a standard 20A DP switch. It would be easy for any customer to confuse two identical isolators that are not labelled. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
