Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Storage Heaters & Central Heating controls Forum
Dimplex Storage Heater CXL N
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mr. shr" data-source="post: 62131" data-attributes="member: 4278"><p>I double checked that I'd tightened all the terminals properly.</p><p></p><p>One thing I did notice is that the live wire on the supply had discoloured slightly (the tip that you insert into the terminal.)</p><p></p><p>Could that indicate anything?</p><p></p><p>I assumed it was discoloured from the previous 13A switch that was always running at about 14A and hence discoloured everything around it.</p><p></p><p>The circuit is protected by a 16A mcb.</p></blockquote><p></p>
[QUOTE="mr. shr, post: 62131, member: 4278"] I double checked that I'd tightened all the terminals properly. One thing I did notice is that the live wire on the supply had discoloured slightly (the tip that you insert into the terminal.) Could that indicate anything? I assumed it was discoloured from the previous 13A switch that was always running at about 14A and hence discoloured everything around it. The circuit is protected by a 16A mcb. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
