johnb2713
The one above was my last reply.John,
I just got my message quote and no reply, was there meant to be a reply?
We have a Franke Hot Tap instead of a kettle, I fitted a diode to reduce the current to half, it now runs at 1500w instead of 3kW. It helps dramatically the shock load on the inverter and as hot water is stored I dont have to wait any longer.when yu say the invertaer can max at 80A, how long for? Most inverters have a short max ampage rating, think spike loads, but won't run at that figure for any length of time.
Kettles are a bit of a pain, as they are a short time heavy load. You coud change it for a lower wattage kettle and just wait longer for it to boil to help the inverter cope with the spike loading.
It does specify maximum discharge rate on the DC Battery port as 80 Amps. That equates to 4kW maximum.Hey Binky, I think 80A is just the nominal output from the battery. It gives separate AC load outputs, says Max continuous is only 28A, or 6kW. 10 minute peak is 41A, and 9kw.
Hey John, I've always fancies one of those taps, but only ever looked at Qooker, and they are something like a grand, too pricey for me.
Assuming they load share correctly, interested to see how this goes.Yeh that's right, or specifically for my batteries at 51.2v, 4096w. But considering I've got two battery banks and two inverters, that's 8kw, so I shouldn't ever need to draw from the grid.
Yes you have to depress the lever and push for the boiling water to be availableIs there a way to stop you accidentally accessing boiling water?
me tooAssuming they load share correctly, interested to see how this goes.
