Hi Theory...
As pointed out by others this is a classic example of balancing between two (or three) points of view of guidance for good practice.
But having no statutory enforcement.. whatever the perceived risks!
With any installation I would consider a good spark will always consider the following key points:-
1) Electrical safety: {in this case probably OK:|}
2) Functional operation: {in this case Crap!
3) Design considerations for probable future use: {in this case Crap!
If you want to cover your back with a letter.. and give a few references...
you could always go something along the lines of:-
Dear Mr
"blah blah"
following my recent work at your property
"anyroad anytown" I would draw your attention to a couple of points with the kitchen wiring which may present a problem to future tenants of the property.
It would appear that the layout of the kitchen has been altered leaving electrical accessories in inappropriate locations. Whilst there is no direct electrical danger, there are areas that do not comply with the various publications which give guidance for good practice within domestic electrical installations.
BS7671 "IEE wiring regulations", recommends where portable equipment is to be used, sufficient sockets should be installed taking into account the length of flex cord normally found on portable appliances. (reg 553-01-07)
IEE "on-site-guide", recommends between 6 & 10 double socket outlets to be installed within a kitchen (table8B page 156).
IEE "Electricians guide to the building regulation", recommends socket & switches should not be mounted over cooking appliances where the user may have to stretch over hot surfaces. (5.2.2 page 56)
Even allowing for the small size of this kitchen I would suggest there are insufficient socket outlets and the outlet that is above the cooker is in an inappropriate location. It is quite probable there will be trailing leads over the cooker whilst the cooker is in operation, which I am sure you can see presents potential hazards.
If you require clarification of any of the above points, or you wish me to quote for any suitable remedial work, please do not hesitate to contact me.
yours the best spark in the area
Theory!!
I would also stick any job no' ref and/or elect cert no' on the letter & refer to the letter in your comments on the cert!
Hope that helps m8
(I guess you may be in bed now.......
but you can read this tomorrow! :^O :^ O)
