Does this sound expesive??
Lillpete
Jan 18, 2009
214
This is what I am doing and what I feel I need to charge, it just seems quite a lot of money to me??
Work to be completed:
Remove existing wall light
Extend cabling for and relocate switch for landing light to new stud wall in dressing area
Install new two-way switch in dressing area
Rewire to existing switch in bedroom to incorporate two-way switching for dressing area
Install 11 down-lights through dressing and sleeping areas
Install cabling for one wall light on dressing area
Install cabling for one wall light on new stud wall on landing
Upgrade existing circuit breaker to RCBO
Test and certificate as required
Materials:
1 X one gang two-way light switch (white)
2 X two gang two-way light switches (white)
11 X fire rated down-lights (available in white/brushed chrome or polished chrome)
1 X 6A RCBO circuit breaker (wylex)
miscellaneous cable/clips/junction boxes etc as required
if you happy with it... sounds fine. how much for materials?
What your Hourly rate.
Realistically expecting the true cost of materials to be
Hi Lillpete,
I find it easy to put everything in a spreadsheet when quoting for work at least then you have got everything down in a clear format especially if the customer is asking about why its such and such price etc!
Also if its a while before doing the work it will help refresh memory to parts needed and length of job.
I have included an excel spreadsheet which might help you, but if you were to show customer this then I would remove markup on materials and also ensure labour showed 2 days work. Obviously I have just put in figures not relevant to your quote.
HTH
ADMIN HELP NEEDED PLEASE!!!
Sorry to shout but its urgent. Can you tell me what I need to do to attach an excel file (.xls) for previous post
Thankyou
ADMIN HELP NEEDED PLEASE!!!Sorry to shout but its urgent. Can you tell me what I need to do to attach an excel file (.xls) for previous post
Thankyou
You can't attach an excel file only bmp doc gif jpe jpeg jpg pdf png psd txt zip. You could compress it as a zip file.
Thanks Apache, thinks I will have to look into this tomorrow as not really sure about zip files etc
That file is brilliant, where I struggle is estimating how long things will take :( so I just went for 2 days but I think by breaking it down like that I may find it easier to guestimate Applaud Smiley
Hi Lillpete,
You are better off quoting for 2 days work even if it isnt gonna take that long cos in reality your not going to finish a job at say 2pm, clear up, tidy your tools away and then go somewhere else, unless of course you have got a quick job just around the corner. Also you shouldnt feel guilty because when your self employed you have to do everything yourself like paperwork, ordering and collecting materials, going out doing quotes etc... so these are all hidden tasks that your customer doesnt see, but will need to pay for.
With the good help of Apache just going to see if I can upload the zip file for the costing file, erm so if someone can open it to check that it works please.
Copy of Costing.zip
  • Copy of Costing.zip
    9.6 KB
