Hi Folks,
I am considering re-using existing ac mains lighting circuits to distribute 24v dc to led lights, supplied by a stand alone solar battery system. Each light has its own SELV rated driver. I have considered the voltage drop issue already and the need for dc rated switches. What I am not sure about is whether to bond the dc negative supply terminal to the ac mains MET and whether it would be accepted as safe to have ELV dc in wiring that is rated for ac (particularly JB connections) and could be mistaken at a later date as ordinary mains cables- even with warning notices at the CCU. Also does anyone know if it possible to get single phase type B (smooth dc sensitive) rcds?
Cheers
Matt
Cheers
Matt
