- Mar 28, 2008
- 13,621
- 297
This is probably is obvious to the more mature sparks on here...
But maybe some of the younger or recent start-ups havent come across these embarassing situations when working in furnished domestic properties....
[ Keep the house clean.]
We all know to keep the work area tidy,
and to clean up when we have finished..
but even silly things like wiping your feet on the customers own doormat can make a real mess if you are walking in & our frequently..
especially if it is a wet day or the ground is damp.
I keep various dust sheets and always make sure I have a large sheet available to use inside the front door, Over the customers door mat to wipe my feet on, as well as the one in the work area.
You only need to go out a few times before the sheet is realy grubby.. (this mess would of been on the customers floor!)
Especially important if you are at a property with CU in garage (risk of oil & grease of garage floor),
or outside (damp & grit off the drive & path)
and you need to walk in & out a lot...
say doing a PIR??
or investigating a fault??
I also keep some of those plastic over-shoe elasticated bag things..
elspecially if going upstairs into bedrooms... or house has pale coloured carpets!
They dont cost a lot, take a couple of seconds to pop on and the customer is dead chuffed you have kept their nice carpet clean.
[ Dont Damage The Ornaments! ]
If you are chasing down to or cutting in a switch or socket on an internal wall...
Double check there are no ornaments on the other side of the wall!!
e.g.
pictures perched on small nails (only just plaster depth)
mirrors, ornamental plates or similar.
statues or glass on top of cabinets leaning against the wall.
The vibration & bangin can be sufficient to cause items to move/slip or fall on the floor!! :| :_|
It gets a bit embarassing when you have to pay for a damaged item which you could of moved easily before you started bangin hammerin & drillin:
say doing a PIR??
e.g.
