Hi all, I'm hoping one of you might be able to point me in right direction. I'm looking for something similar to this https://hartingtonheath.com/product/i-lumos-as-luxury-white-plastic-arc-double-20a-switch-with-switched-13a-uk-socket/ with a flex outlet on 20am switch side? I've replaced my dad's night storage heaters with new Dimplex Quantum versions which also have "peak" supply heat option integrated which they state must be connected to a 20a DP switch. Other than the the NSH "off peak" outlet the nearest socket is a standard double gang socket and i was hoping to simply replace this as there is not much room to spur another outlet. Please let me know if this exists? Thanks for any assistance you can give.
