Ptaylor512
- May 5, 2020
- 1
- 0
Hiya all!!! I have the following issue :
I have removed my living room double light dimmer switch and I( think) I have replaced the wires into the correspondening holes on a new double switch. (4 red wires 1 into each L1, one into each Com as well as a bridge between the Coms). However - this now does not work the lights independently. One switch works both lights the other switch doesn't do anything. Also, if the light switch isn't turned on in the living room the lights in both the dining room and downstairs hallway will not come on at all! The wires come into the wall bracket from above the plate so I can't check which red wire comes from which main wire.
Amy help will be greatly appreciated.
Cheers
Cheers
