This is the best answer you could get.Not all stud walls are fire barriers but you do need to find out from the designer of the building whether or not the sud wall is a fire barrier if it is then you need to use the fire rated ones.
Ah, now it makes sense. I was under the impression that if you broke the integrity of any plasterboard partition, then you had to re-instate it with fire/acoustic rated boxes.Not all stud walls are fire barriers but you do need to find out from the designer of the building whether or not the sud wall is a fire barrier if it is then you need to use the fire rated ones.
You will have a responsibilty to maintain the acoustic integrity, if the partition requires this. Its not always just fire regulations.Ah, now it makes sense. I was under the impression that if you broke the integrity of any plasterboard partition, then you had to re-instate it with fire/acoustic rated boxes.Many thanks for clearing that up. I don't know how it would work out on older premises though, I suppose if in doubt, fit them, or does it only apply to new builds?
I think the object of a fire rated box is to maintain the fire-proofing of the wall to it's given rating, ie 15 mins, 30mins, etc. Once the fire is through the wall I thing the cable is the least of your worries:Oand whatabout using fp cabling inside the firewalls?
