Nicky Tesla
- Apr 30, 2008
- 1,638
- 0
All the books tell you to isolate the electrics by switching off the DB, then put in a temporary connection between the busbar or phase conductor to the earth bar, and then to take a reading at the accessory to get r1+r2.
After you have done this you may need to refit the accessorys in an occupied house, remove the temporary link, and then go round undoing all the fittings again to get a Zs reading at fused spurs etc.
My way saves loads of time and inconvenience.
r1 is normally thought to be the phase conductor, but it is actually the neutral conductor also. What I do, is undo the accessory, take r1+r2 on the live cct but from neutral to earth, then take Zs readings as normal and then refit the accessory. Job Done.
If there is an RCD on a split board, the r1+r2 test will trip it out still, so just put in a temporary link between the two neutral bars. Easy.
