Easycert
DonkeyDong
Mar 14, 2008
218
Question to all the guys/gals that run EasyCert...
You have the columns for the various Insulation Resistance tests Line/Line, Line/Earth, Line/Neutral and Neutral/Earth. But what do you do when you have to Line and Neutral/Earth test ?
Many thanks,
D.
Fill results in to all columns & put note in "agreed limitations (or some type section)" that test was undertaken as L&N / E & give reason why it was done this way.
Thanks guys :)
So you put the L/N to E result in all the columns?
Thanks,
D.
