Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Central Heating & Storage Heaters Forum
Economy 7 useless
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Blue Duck" data-source="post: 453384" data-attributes="member: 8071"><p>:Welcome: </p><p></p><p>Yes well.... it can be useless, depends on how it is utilised.</p><p></p><p>The whole idea is that you use cheap rate electricity over night usually between 11pm and 6am so if you have a hot water tank on a second timer It may not be heated for long enough to provide you with a hot shower at 4am.</p><p></p><p>What are timings you use? </p><p></p><p>Is the hot water cylinder well insulated,?</p><p></p><p>What have you had replaced recently?</p></blockquote><p></p>
[QUOTE="Blue Duck, post: 453384, member: 8071"] :Welcome: Yes well.... it can be useless, depends on how it is utilised. The whole idea is that you use cheap rate electricity over night usually between 11pm and 6am so if you have a hot water tank on a second timer It may not be heated for long enough to provide you with a hot shower at 4am. What are timings you use? Is the hot water cylinder well insulated,? What have you had replaced recently? [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Economy 7 useless
