Traineeboy
- Apr 22, 2020
- 201
- 17
Just some questions relating to EIC. I’m fairly new but have some questions I would like to Clarify as getting different answers from people on my placement.
1. If you are filling out an EIC ( ticking the box for additions to an existing installation). If you installed a garage CU then I know you have to fill out to schedule of test sheets 1 for the main DB and one for the garage DB. On the Garage DB I will obviously fill out and test all circuits as I would have installed them but on the schedule of test sheet for the main DB I would of just installed the swa from a breaker to feed the garage CU, so although there is like 10 circuits on the main CU I assume I just have to test and record the 1 circuit I installed ?
2. If you are just filling out an EIC because of an addition then do you need to fill out the sheet for inspection? As at the top it says it’s just for New Installations only. But I’ve been told even if you are making an addition to an existing installation you still have to fill in the schedule of inspections sheet. please could someone clarify.
thanks
thanks
