Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrical Inspection & Testing Forum
Elec Hob And Oven
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="NozSpark" data-source="post: 338509" data-attributes="member: 601"><p>To answer your pm...</p><p></p><p>You can isolate via a std 45A iso switch as you would a normal cooker then take a single 6.0 twe to the click dual outlet</p><p></p><p>Another way if doing it would be to have a cooker outlet plate and single socket fed from the iso switch (both in a dual accessory pattress)</p></blockquote><p></p>
[QUOTE="NozSpark, post: 338509, member: 601"] To answer your pm... You can isolate via a std 45A iso switch as you would a normal cooker then take a single 6.0 twe to the click dual outlet Another way if doing it would be to have a cooker outlet plate and single socket fed from the iso switch (both in a dual accessory pattress) [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Elec Hob And Oven
