Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Electric Fireplace and fridge off fcu help
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Alarmist" data-source="post: 561358" data-attributes="member: 30011"><p>Fridge might have a high start up current but only short term, that's why they recommend a 13A fuse, running current is lower. Everything should be ok as is, if, as you say, you've changed the socket for new. As previously mentioned, just keep an eye on the socket the fire's plugged into.</p></blockquote><p></p>
[QUOTE="Alarmist, post: 561358, member: 30011"] Fridge might have a high start up current but only short term, that's why they recommend a 13A fuse, running current is lower. Everything should be ok as is, if, as you say, you've changed the socket for new. As previously mentioned, just keep an eye on the socket the fire's plugged into. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
