sparkattack
- Dec 14, 2010
- 61
- 0
Hi, ive got to replace a gas hob for an electric hob. At the moment the electric fan oven runs off 2.5mm to a fused spur on a 13a fuse and then on 6mm cable back for consumer unit on a 32a mcb. My question is ive worked out the 6mm cable and run both the hob and oven but cant think how i can wire it because i very very much doubt id get three 6mm cables into one cooker isolator switch, and then from that to hob, and for the oven to a fused spur and then 2.5mm to the oven. Would a 30a junction box to seperate the 6mm be acceptable you think? then take one 6mm to hob, and one 6mm to a fused spur and off in 2.5mm to oven. only way i can think off.
Normally i would use a socket outlet for the oven but its on other side of kitchen
