Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Electrics tripping RCD
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mort2376" data-source="post: 559174" data-attributes="member: 25787"><p>Just so you can budget an Rcbo board change will be anywhere from £750 - 1300 depending on manufacturer and if your earth bonding requires updating at the same time.</p><p></p><p>Also if there are faults found on circuits these will need to be rectified or they won't be connected.</p><p></p><p>A good electrician will carry out some testing prior to even starting the board change to identify any issues.</p><p></p><p>If faults are found and rectified this will of course increase the costs.</p></blockquote><p></p>
[QUOTE="mort2376, post: 559174, member: 25787"] Just so you can budget an Rcbo board change will be anywhere from £750 - 1300 depending on manufacturer and if your earth bonding requires updating at the same time. Also if there are faults found on circuits these will need to be rectified or they won't be connected. A good electrician will carry out some testing prior to even starting the board change to identify any issues. If faults are found and rectified this will of course increase the costs. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
