jurassic spark
I am currently doing some remedial works to emergency lighting for a supermarket chain, the surveys have been carried out by someone else and I have been given a "pass / fail" on each fitting, I just have to repair or replace, so far so good.
My problem is that each store seems to have been surveyed by a different person and they all seem to have a different interperatation of BS5266. The main point of contention being when a test keyswitch takes out more than just the emergency lighting in an area. An example of which is in a cafe area, there are three customer toilets, ladies, gents, disabled plus babychange room and a common corridor linking them. There is one test keyswitch for this area located in an adjacent plantroom, it takes out all the lights in this area. The building is only a year old so you would expect it to comply.
One train of thought is that it does comply because it simulates a power failure, however it could potentially present a dangerous situation if the switch was operated during trading hours when the area was occupied. but this is very unlikely to happen as it should be tested out of trading hours.
I have read BS5266 and it says "each system should have suitable means for simulating a failure of the normal supply for test purposes". So does it comply or not? and if it doesn't, where does it say so?
Your views please.
Your views please.
