- Feb 5, 2009
- 5,612
- 1
I've been doing some maintenance for another spark in a big cash n carry. He tells me what to do and I do it. He's not there most of the time so let's me get on with it. I've explained that I know about domestic but never done anything else so if I think it's too hard or I'm unsure I get him to do it and he's fine with this.
I ran a new fp200 gold across the girder using girder clips to hold. I'm not sure how this circuit was wired and was told to replace the cable. Disconnect the pyro and reconnect the pf200g. I checked for voltage at the key switch which was fine and checked voltage at the control box for em lighting which was ok. I wasent asked to check the circuit out just replace the cable.
As voltage was present where it should have been I can't understand why the cable needed replacing. But one of the pots had come off the pyro by the control box. I know this wrecks the ir readings for the cable but would it cause the em lighting to fail. It wasent shorted out. No mcbs were tripping and no rcds here.
Any advice appreciated and if it doesn't make sense just ignore me.
Matt
Matt
