Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
EV charging lead
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="sparky308" data-source="post: 560780" data-attributes="member: 1001"><p>I'm using a BG weatherproof socket to charge my EV with no problems. But I did set the charge rate to 10 amp rather than the maximum of 13 to avoid overheating. I don't see that this is an 'improper' solution - it just takes longer than a 7kW charger, which doesn't matter at all to me. One overnight charge per week is fine for my mileage.</p></blockquote><p></p>
[QUOTE="sparky308, post: 560780, member: 1001"] I'm using a BG weatherproof socket to charge my EV with no problems. But I did set the charge rate to 10 amp rather than the maximum of 13 to avoid overheating. I don't see that this is an 'improper' solution - it just takes longer than a 7kW charger, which doesn't matter at all to me. One overnight charge per week is fine for my mileage. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
EV charging lead
