Exam Question
Aug 30, 2012
1,450
36
In the sticks…
Hi guys.
I would be really grateful if you could help to explain an exam question that I got stuck on earlier. I did ask my teacher but he just said that although we've learnt about magnetic fields we haven't gone through that bit yet.
The question was:
In a magnetic circuit the magnetic field strength H is expressed in ampere turns/metre. H is calculated using the formula
a) H=i/nl
b) H=ni/l
c) H=il/n
d) H=nl/i
I guessed option b), on the basis that I was thinking "something current divided by length". But I'm not sure if it's right. If you could please explain this to me that would be great.
Thank you.
Nov 9, 2012
3
Hello Miss Sweden
Magnetic Field Strength (H) is generally the magnetomotive force per unit length of a magnetic circuit
Often expressed in amperes per metre (A/m) - which is often spoken as "'ampere turns per metre".
The correct equation is
H = (in) / l
where:
H = magnetic field strength (ampere per metre)
i = current flowing through the coil (amperes)
n = number of turns in the coil
l = length of the magnetic circuit
So your guesswork was correct
