ian932
Can anyone recommend a good joint system for extending a 6mm T&E the joint will not be accesible for servicing so it needs to meet the recuirements of section 526 othe the 17th, thanks
Do these have to be accessible?
These look like the business cheers for that Theory, much better then messing about with crimps etc. I'd happly spend the clients money on these and save me time as well Applaud SmileyNo they dontyou put them in the grey box job done
http://wagobox.com/
quick and easy ,,,did a job extending 6 ccts under floorboards took me no time really
What are these " New non mainenance joints) I've not heard of them PrayWell to be truthful 90% are wrong then! JB's (unless they are the new non-maintenance versions) need to be accessible.Fully agree with the soldering idea though. Better than crimping in the long run!
the push fit ones grip the cable and wont come out if pulledAh, right... I use them a lot .. what makes them " No maintenance " Surely anything mechanical can go wrong ?
Register today and take advantage of membership benefits.
