Exterior SWA Junction
ADS
Dec 15, 2009
930
Can anyone suggest a good, suitably rated, adaptable/junction box, with connectors, for mounting on an exterior wall. (not too pricey)
It needs to be able to accept two 16mm SWA from the bottom and a 16mm SWA from the rear (through the wall)
A link would be great.
Cheers.
Just use a suitably sized IP rated adaptable box and CW glands
Yeh, I can look around and find something suitable - just thought someone might have used something themselves, for something similar, and could recommend. :)
How do you propose to make off the SWA in the back of the box, Ads ?
Well, this is the reason for the thread, Deke.
I was thinking it wouldn't be too tricky - but, on reflection, the second end might be:)
I could run ordinary 16mm through - but it still needs to go out the back of the box, unless there's a better way?? :) ....I hate working with 16mm - singles are bad enough!
Hi,Can anyone suggest a good, suitably rated, adaptable/junction box, with connectors, for mounting on an exterior wall. (not too pricey)
Cheers.
IMHO glands should be accesible for inspection
Would you just run 16mm T&E through the wall then? If I remember correctly, it would need mechanical protection as well.
The set up is this:
A 16mm sub-main running around the outside of the building into 'said' junction box.
A 16mm feed off this box then going through the wall to feed a CU.
At a future date, a continuation off this junction box to feed a shed and log cabin.
Any other suggestions on doing this, other than what I am trying to do??
Well you'd run 1.0mm T&E without extra mechanical protection through a wall to an external light; or 2.5mm T&E to an external socket.... if you want to protect it from debris in the cavity then put some 1 1/2" pipe through the wall and use T&E, maybe with an extra 10mm earth if you need it
or
Have the glands accessible and run the SWA through the wall and back up to the new CU
I did think of doing this - and then coming off the new CU at a later date for the additional work.
What stopped me was the thought of trying to get 16mm SWA to look neat going through a brick wall - and especially coming out the other side - it's hardly the most flexible stuff. :)
I just thought that an Adaptable box, inside and out, would look a lot neater.
you could simply cut/file the adaptable box as a shroud for the cable entry,
I have done something similar loads of times, simply to cover an entry/exit point.
