FCU on Cooker Circuit
DCM2039
Jun 17, 2008
15
1st Post and wondering if someone can help
Today I removed a stand alone cooker and hob from between two kitchen units and found that the cooker outlet behind had a FCU connected to it. The FCU is supplied from the cooker outlet by a 4mm T&E and the cooker outlet is supplied with a 6mm T&E coming from the cooker isolator. The cooker also has a 6mm cable going into the Outlet. The FCU isn
Mr Sworld
Electrical Technician
Mar 21, 2008
1,152
1st Post and wondering if someone can helpToday I removed a stand alone cooker and hob from between two kitchen units and found that the cooker outlet behind had a FCU connected to it. The FCU is supplied from the cooker outlet by a 4mm T&E and the cooker outlet is supplied with a 6mm T&E coming from the cooker isolator. The cooker also has a 6mm cable going into the Outlet. The FCU isn
Theorysparky
Domestic Electrician
Feb 18, 2008
4,233
Welcome to the forum mate from the day shift
this set up is ok
as long as the fcu has the correct fusing and cable for the appliance it is feeding
Theorysparky
Feb 18, 2008
4,233
Mr S
you hadnt replied when i started composing
makes my post a bit limp :)
Admin1
Forum Founder
Feb 6, 2008
10,278
-1
Concur with those two ^.
Welcome to the forum from the Day & Night Shift. :D
Mr Sworld
Mar 21, 2008
1,152
Mr Syou hadnt replied when i started composing
I saw you posting and pipped you to the post! :p
DCM2039
Jun 17, 2008
15
Thanks for the quick replies guys, very helpful. And for making me feel welcome to your forum. I hadn
Admin1
Forum Founder
Feb 6, 2008
10,278
-1
:^O
You're not having any of my Twix now - for stirring. X(
:^O
DCM2039
Jun 17, 2008
15
Thanks for the reply Mr Sworld and very informative too.
Unfortunately, my other half has now decided that she doesn
Mar 7, 2008
9,994
In the office again.
Hi mate.
Right. If you`ve got a 13A socket on the cooker unit, you add 5A to the total.
You take 10A to start, then 30% of the remainder - ergo:
10.3KW @230V =44.79A
minus the 10A already accounted above, leaves 34.79A
30% of this =10.44A
Add together 10A, 10.44A and 5A(if socket outlet)
gives 25.44A after diversity
OK?
n.b. I`d STILL change the 3036 for a plug-in MCB though!
KME
