Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
first domestic rewire, opinions please.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Steve3948" data-source="post: 271076" data-attributes="member: 2497"><p>:Applaud :Applaud:Applaud</p><p></p><p>I have seen these metal frames before, they came complete with door and locks already fitted, this was a block of flats in Oxford back in the late 70's, not seen them since, the walls were made with Stramat board or something like that, compressed straw with layered paper both sides, the board had a couple 20mm holes top to bottom, and you cut out for boxes with jigsaw then glued box in with Stramat glue before straw expanded, it was a load of s**t.</p></blockquote><p></p>
[QUOTE="Steve3948, post: 271076, member: 2497"] :Applaud :Applaud:Applaud I have seen these metal frames before, they came complete with door and locks already fitted, this was a block of flats in Oxford back in the late 70's, not seen them since, the walls were made with Stramat board or something like that, compressed straw with layered paper both sides, the board had a couple 20mm holes top to bottom, and you cut out for boxes with jigsaw then glued box in with Stramat glue before straw expanded, it was a load of s**t. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
