first job mist
chrisgjudd
Apr 18, 2008
15
hi guys, finally got my first telephone call to ask to fit a new cooker, electric double oven. They have an existing one. The instant thoughts i had was at what wattage can i not put the cooker on a 30/32amp, should i use 6 or 10mm, and its just the case of a new piece of cable do i do a minor works??
Also just for arguments sake whats the best practice if the cooker socket circuit is not man enough for the new cooker and there isn't room at the cu, can i add an additional fuseway seperate to the cu supplying eg 45a.
Realizing these are a reflection of my greenness but i like to get things right, any help greatly appreciated.
Chrisgjudd
Theorysparky
Domestic Electrician
Feb 18, 2008
4,233
hi guys, finally got my first telephone call to ask to fit a new cooker, electric double oven. They have an existing one. The instant thoughts i had was at what wattage can i not put the cooker on a 30/32amp, should i use 6 or 10mm, and its just the case of a new piece of cable do i do a minor works??Also just for arguments sake whats the best practice if the cooker socket circuit is not man enough for the new cooker and there isn't room at the cu, can i add an additional fuseway seperate to the cu supplying eg 45a.
Chrisgjudd
Chris
Have you seen the job ?????
Admin1
Forum Founder
Feb 6, 2008
10,278
-1
There's nothing stopping him fitting a mini CU next to the Main CU or in the Kitchen ete, is there?
Or he could even use the existing way in the board, currentl used to supply the ccu.
montybaber
Oct 17, 2008
54
Best thing is to go and see the job in the flesh before you start any planning etc, who knows what you will find when you get there!
When you do take your time and chk everything, dont rush and miss stuff (which is very easily done)
heathelect
Domestic Installer
Oct 17, 2008
92
Chrisgjudd
HIYA MATE I AGREE WITH THE OTHERS, GO AND LOOK, EVALUATE THE JOB, IF CONSUMER IS OLD AND EARTHING NEEDS UPDATING, TELL THEM, YOULL BE SURPRISED HOW HAPPY PEOPLE ARE WHEN YOU EXPLAIN WHATS NEEDED TO MAKE SAFE, SO THAT WILL MEAN MORE
Jun 21, 2008
17,033
21
Indeed m8. Is it me, or does anyone else get the impression of schizophrenia abounding????
I try to keep up with things on here. I usually do other stuff too. I've not even checked my hotmail yet. Tonight it's manic. I'm knackered just saying hi. Poor ole admin 2 is working her socks off playing 'hostess with the mostess' comparing cardiff stories.
I'm about ready for a nap
:D
Robbo
Oct 12, 2008
105
I try to keep up with things on here. I usually do other stuff too. I've not even checked my hotmail yet. Tonight it's manic. I'm knackered just saying hi. Poor ole admin 2 is working her socks off playing 'hostess with the mostess' comparing cardiff stories.I'm about ready for a nap
:D
Lightweight ! Guiness Drink
Robbo
Oct 12, 2008
105
Chrisgjudd
Just take a feed off the nearest ceiling rose. You may have trouble terminating 6mm in there though. 6 core alarm cable will do the trick. ; \
Feb 27, 2008
11,034
Chrisgjudd
A 30/32 circuit will be adequate for most ovens even double ovens. But take a look a job. A minor works certificate will be adequete for changeover.
batty
Robbo
Oct 12, 2008
105
Sorry... first night excitement and all that.
On a serious note firstly check the wattage of the new one.
Then check to see if the Dis Board is up to scratch with earthing conductors and main equipotential bonding present.
Check to see if theres a spare way.
Jun 21, 2008
17,033
21
Sorry... first night excitement and all that.On a serious note firstly check the wattage of the new one.
It's so easy to be helpful when you try. :)
Mar 28, 2008
13,620
296
Chrisgjudd
Hi Chris..
as has been pointed out..
You really do need to go and have a look at the job..
A cooker is most probably the second largest electrical appliance in the property after an electric shower!
So no assuming things are OK without checking!
Find out the power rating of the new cooker..
remember diversity to be applied.. (Pg 96 OSG.)
first 10A + 30% of rest + 5A if socket outlet..
Check length of cable run & probable thermal insulation etc..
REMEMBER!
REG 131.8 Additions & Alterations.. temp OR permanent
must check condition of existing equipment / loading / earthing & bonding!
Obviously if not adequate.... it could ramp a few more costs onto the job.
Can be handy to have copy of Regs available to show customer if they question your judgement if stuff need upgrading! :) ;)
sparkyrj
May 29, 2008
180
Burnham
I could be wrong here, but it seems to me that they are just asking for the new cooker to be connected to the existing circuit replacing the cooker they have now.so as long as the circuit is the correct rating etc no problem.
