Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Intruder, Fire, CCTV, Emg Light, Access Control
Fitting window contacts onto pvc
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="scouse" data-source="post: 247173" data-attributes="member: 3946"><p>Dependant on the type of contact your mate has fitted it may not be possible to glue them</p><p></p><p>if they are the old style open type there is knowhere to put glue to stick them</p><p></p><p>I can tell you which ones you need if you need to change them, they are called SC550 Heavy duty contacts and also have a 20mm operating gap which is great for the round bead/style windows.</p></blockquote><p></p>
[QUOTE="scouse, post: 247173, member: 3946"] Dependant on the type of contact your mate has fitted it may not be possible to glue them if they are the old style open type there is knowhere to put glue to stick them I can tell you which ones you need if you need to change them, they are called SC550 Heavy duty contacts and also have a 20mm operating gap which is great for the round bead/style windows. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
