Flashing LEDs
Deckie
Mar 14, 2025
UK
I fitted a wall light with two 4w G9 LED dimmable bulbs and connected it to a dimmer switch. When I turned the dimmer switch on and faded it up the lights came on but above a certain brightness they flash (not flickering, they alternately flash about once a second). When I dim them again they glow steadily when it reaches about half way. I’ve never seen this happen before, is it due to the bulbs or the dimmer switch? Should I change the bulbs to halogen?
As NozSpark almost said, it's a compatibility problem between lamp and dimmer. I am not saying the following is g'teed to solve your problem, but I suggest a programmable dimmer, the original one I have is no longer available, but has a replacement Click me do follow the instructions to the letter, and if it doesn't work for you, you can send it back.
What ever you do, please let us know.
Write your reply...
