Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
flat and auger wood bits
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Barx" data-source="post: 527170" data-attributes="member: 121"><p>Bosch self cut every time. you can frop on them cheap enough on amazon. Get a set of them by all means then you will have a variety, but I only ever carry 25mm normal, 14mm and 25mm long. Never really find myself needing anything else when it comes to holes in wood for cables.</p><p></p><p>Edit: oh and cheapo 20mm flat bit just for hole in plasterboard when you are surfacing something in YT2. 25mm can be a bit big for that and leave a bit of mess on show.</p></blockquote><p></p>
[QUOTE="Barx, post: 527170, member: 121"] Bosch self cut every time. you can frop on them cheap enough on amazon. Get a set of them by all means then you will have a variety, but I only ever carry 25mm normal, 14mm and 25mm long. Never really find myself needing anything else when it comes to holes in wood for cables. Edit: oh and cheapo 20mm flat bit just for hole in plasterboard when you are surfacing something in YT2. 25mm can be a bit big for that and leave a bit of mess on show. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
