Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Do-It-Yourself (DIY) Question & Answer Forum
Flickering Light
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="SPECIAL LOCATION" data-source="post: 38214" data-attributes="member: 250"><p>If pendant fittings..</p><p></p><p>physically swap two pendant around in the house..</p><p></p><p>the ficker position with a non-ficker..</p><p></p><p>see if the fault moves</p><p></p><p>OR..</p><p></p><p>How far away is the job?</p><p></p><p>borrow the light bulb and bring it home,</p><p></p><p>try it at you own house for a day or two.</p><p></p><p>Both easier &amp; cheaper than lifting floorboards and possibly not finding anything? <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="SPECIAL LOCATION, post: 38214, member: 250"] If pendant fittings.. physically swap two pendant around in the house.. the ficker position with a non-ficker.. see if the fault moves OR.. How far away is the job? borrow the light bulb and bring it home, try it at you own house for a day or two. Both easier & cheaper than lifting floorboards and possibly not finding anything? :) [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
Flickering Light
