tomtom27
hello every one i was wondering if you can help.
im a maintnenance engineer and only usualy diagnose and rectify electrical faults on production machinary, very rarely instalation so im a bit rusty with calculations and probably way out ith these.
we are instaling some 5ft fluorscent lights at work (i say some its about 100), running trunking, cables the lot. i need to work out the load of the fittings.
this is whats on the fitting.
Lamp In 230v/50hz PF
T5 2x49w 0.452 0.98
so i would say 500ma per fitting, i even rigged one up on the bench with a meter and yes it was drawing .45amps.
how would i work this out on a formular to check this is correct?
i used this,
VAxPF/V so volt amps = 230x.452= 104
so 104x0.98/230= 0.443, is this formular correct??
my boss said when calculating the load of fluro fittings you use 1.8 as a figue for somthing and he said thats were people go wrong so now im a bit lost, do i use this instead
104x1.8/230? = amps.
like i said i might be way out with this anyway but i hope somone with more knowledge on this type of thing can help.
many thanks to all
tom.
T5 2x49w 0.452 0.98
i used this,
many thanks to all
tom.
