collumgary
- Dec 17, 2008
- 6
- 0
Hi, I have a flurescent lighting problem if anyone can help?
when i test between live and earth I get 240V, but when I test between live and neutral I 50V. wall light fed from the same live connection works.
I disconnected the live and neutral from the light and got 240V between them.
Dose this volt drop have anything to do with ballast or cappacitor failure?.
Also flurescent next door has also fail (24hr latter) and seems to have the same problem, 50V between live and neutral.
This is wired on the same circuit down stream, could the first light failing affect the scond?.
The first light is switched by a dimmer, can this cause failure due to wrong operating voltage?.
Thanks for any help.
