Every house on an older estate near me has this arrangementHow common is this 'a fuse at the cutout feeding the property next door?
See post #2 :innocentmost times its just an unfused loop to the next property. sometimes via a fuse, although any fuses are probably replaced with a solid link
I work for contracting side of a DNO, we do quite a bit of work for our owners.I think all these things were to save money on network installs . Don't think we have any DNO guys to ask on here anymore.
I've seen a lot of cut outs with two cables made into the bottom , one looping to next door. Where I live , one cable comes in between the two houses with a joint off to house next door.
I've found the same. An estate of maisonettes with the supply coming into the ground floor, two fuses and one set of tails going into conduit to upstairs!Every house on an older estate near me has this arrangement
Pre 1960s
I've had many calls to a power cut but no access next door
Also had hot/burnt tails at the head feeding next door involving the dno coming out and relaying new cable and a new service head
Interesting Kelvfooz , so you are the contracting side of Western Power or whoever . Is your firm there to support the DNO or do they do their own thing too?I work for contracting side of a DNO, we do quite a bit of work for our owners.
Had a job a while ago from local council where a builder had charged a tennant for decorating etc in the lounge and not completed the works before buggering off home to eastern europe. Semi-detached property with a looped pilc (lead sheathed oil blah cable) coming into the affected property and looping to next door. In a normal situation, this wouldn't be a problem, but the builder decided to move the consumer unit from the front room to under the stairs. This involved removing the live cut out from the wall, throwing it under the floor and dragging it to the other side of the building. He then fitted long tails to the meter, screwed to a brick wall and left the cutout under the floorboards.
We had to completely re-wire the place, and replace the looped service with new, jointed out in the street, and access next door to replace their service. The new consumer unit we fitted went under the stairs, so she got the work done eventually, not that she had permission for any of it!
I also, often, have to find isolation for landlords metering, flats etc. We have some locally with shops below with 3p cutouts that feed the flats above in VIR singles in tube, and are only fused in the shops below, with no isolation before the meter in the flats. It's a mess!
