Fused Isolator
Oracle
Feb 8, 2009
155
All,
I am after a small metal (ideally - but could be plastic) switched single phase fused isolator to go in some meter tails.
I believe Mem do a unit?
Many thanks,
Oracle
Price cockup on the Click DB750 80a switchfuse now sorted! Click changed their pricing structure at the beginning of February, including this item which had loaded up to the web without discount (Sounds like standard wholesaler policy but definately not intended :) )
Apparently it comes with shroud.
Can I ask a big favour please. We are not in the business of overcharging, but with 6000 products to maintain and not having the company size to have a department maintaining it, just me, the odd mistake does get through. If you see anything like this that does not look right drop me a PM.
Price cockup on the Click DB750 80a switchfuse now sorted! Click changed their pricing structure at the beginning of February, including this item which had loaded up to the web without discount (Sounds like standard wholesaler policy but definately not intended :) )Apparently it comes with shroud.
I did think it was a bit of an odd price, but not finding any other prices at that time for this item I had nothing to compare it to.
If I find anything like this again I will certainly PM you "Is this the correct price??".Blushing
Hi there,
Do you know what size terminals the 60A Wylex metal clad unit has?
Will it take 25mm cable?
Oracle.
Yeeehaaaa
Cowboys :D
But as long as it is tested to an equivalent/acceptable standard then its find.
Oracle.
ps - Good job I'm only interested in the wylex one!
I'm a bit concerned about this statement in the MEM datasheet though...."The 800KMF is a well proven design but has not been tested to any current British Standard."
I should really withdraw the MEM 800KMF (I'll have to now its in the public domain) pdf as there was no info available from Click and the two units bare a 'striking' similarity to each other. I have tweaked the page now
