Many thanks Tech. For clarification they are only required on three phase systems? What if the PV system is single phase, however forms part of a three phase supply ie the main incomer is three phase??
You can get smallish 3 phase inverters starting at 5kW. if you have 3 phase supply you can install 12kW without talking to DNO, though if you ask nicely they may let you have a bigger system assuming you have the roof space. Some popel also fit 3 small inverters, 1 per phase, but I'm not convinced that they would balance properly.
