Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Garage Feed from House
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="apprentice87" data-source="post: 432927" data-attributes="member: 13534"><p>There you go then, Just for your information NO electrical calculations are based on 240V because that is NOT the voltage used here. Do not know where you got the programme as you will not say, but it is a piece of junk....</p><p></p><p>As to the question as to what difference would the voltage make to the cable calcs, this was just to test your knowledge and understanding a bit, problem is you have no idea at all... I will give you a hint "disconnection times" Write an essay on that and factors related to it and publish it on here..</p><p></p><p>Without being rude, it also appears that you do not what to learn, and think that you "know it all"</p><p></p><p>Good luck...</p><p></p><p>john..</p></blockquote><p></p>
[QUOTE="apprentice87, post: 432927, member: 13534"] There you go then, Just for your information NO electrical calculations are based on 240V because that is NOT the voltage used here. Do not know where you got the programme as you will not say, but it is a piece of junk.... As to the question as to what difference would the voltage make to the cable calcs, this was just to test your knowledge and understanding a bit, problem is you have no idea at all... I will give you a hint "disconnection times" Write an essay on that and factors related to it and publish it on here.. Without being rude, it also appears that you do not what to learn, and think that you "know it all" Good luck... john.. [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
