workwright
Hi, First Happy New Year. Second a question. The lathe is a reallly nice machine but was rather unloved, so before use I am returning it to ex-works condition. The first job was to remove the integral splash back since somebody had tried to secure the 800Kg Lathe by taking the cargo tie over the splashback, result bent plate. Hopefully the local bodyshop will get it sorted out. In doing this I found the main spindle of the lathe was locked and would not turn. So here is my question. I got inside the drive system part of the cabinet and found the spindle turns fine with the polybelt removed from the drive motor but the drive motor appears to be locked up solid. I now have a brochure for the lathe and it says "equipped with electromechanical spindle brake" The motor is made by ELIN I will post the plate details tomorrow, It is a dual voltage 3HP 3 phase motor. The Motor seem longer than normal and has two separate cables to its connection box. If this is an electomechanically braked motor is it correct that with NO power supply to the lathe it is in the braked state, and will only become free to turn when there is power getting to the machine? Have these motors a manual overide/brake release to use when re-fitting and tensioning drive belts? Any help and advice would be welcome. The lathe was manufactured in the late 1990s. Thanks.
