*-ide:1
description: IDE interface
product: VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE
vendor: VIA Technologies, Inc.
physical id: f.1
bus info: pci@0000:00:0f.1
logical name: scsi2
logical name: scsi3
version: 07
width: 32 bits
clock: 33MHz
capabilities: ide pm bus_master cap_list emulated
configuration: driver=pata_via latency=32
resources: irq:0 ioport:1f0(size=8) ioport:3f6 ioport:170(size=8) ioport:376 ioport:e000(size=16)
*-disk
description: ATA Disk
product: ST380011A
vendor: Seagate
physical id: 0.1.0
bus info: scsi@2:0.1.0
logical name: /dev/sdb
version: 8.16
serial: 5JVSN4XX
capabilities: partitioned partitioned:dos
configuration: ansiversion=5 signature=000943bd
*-volume
description: EXT4 volume
vendor: Linux
physical id: 1
bus info: scsi@2:0.1.0,1
logical name: /dev/sdb1
version: 1.0
serial: 838bf321-4d72-4712-bf02-0fac17009bc5
capacity: 74GiB
capabilities: primary bootable journaled extended_attributes large_files huge_files dir_nlink extents ext4 ext2 initialized
configuration: created=2010-11-20 21:42:34 filesystem=ext4 label=Disk 2 lastmountpoint=/media/Disk 2U�=�H��Hq���ꔞ�ꅁ ���/�����~1!�������H modified=2011-09-14 23:54:41 mounted=2011-09-14 21:43:32 state=clean
*-cdrom
description: DVD writer
product: DVD8801
vendor: PHILIPS
physical id: 0.0.0
bus info: scsi@3:0.0.0
logical name: /dev/cdrom
logical name: /dev/cdrw
logical name: /dev/dvd
logical name: /dev/dvdrw
logical name: /dev/scd0
logical name: /dev/sr0
version: NW02
capabilities: removable audio cd-r cd-rw dvd dvd-r
configuration: ansiversion=5 status=nodisc
*-usb:0
description: USB Controller
product: VT82xxxxx UHCI USB 1.1 Controller
physical id: 10
bus info: pci@0000:00:10.0
version: a0
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list
configuration: driver=uhci_hcd latency=32
resources: irq:20 ioport:dc00(size=32)
*-usb:1
physical id: 10.1
bus info: pci@0000:00:10.1
version: a0
width: 32 bits
clock: 33MHz
resources: irq:22 ioport:d800(size=32)
*-usb:2
physical id: 10.2
bus info: pci@0000:00:10.2
version: a0
width: 32 bits
clock: 33MHz
resources: irq:21 ioport:d400(size=32)
*-usb:3
physical id: 10.3
bus info: pci@0000:00:10.3
version: a0
width: 32 bits
clock: 33MHz
resources: irq:23 ioport:d000(size=32)
*-usb:4
product: USB 2.0
physical id: 10.4
bus info: pci@0000:00:10.4
version: 86
width: 32 bits
clock: 33MHz
configuration: driver=ehci_hcd latency=32
resources: irq:21 memory:dfffe000-dfffe0ff
*-isa
description: ISA bridge
product: VT8237A PCI to ISA Bridge
physical id: 11
bus info: pci@0000:00:11.0
version: 00
width: 32 bits
clock: 33MHz
capabilities: isa pm cap_list
configuration: latency=0
*-network
description: Ethernet interface
product: VT6102 [Rhine-II]
physical id: 12
bus info: pci@0000:00:12.0
logical name: eth0
version: 7c
serial: 00:19:db:36:84:fb
capacity: 100MB/s
width: 32 bits
clock: 33MHz
capabilities: pm bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=via-rhine driverversion=1.4.3 duplex=full ip=192.168.1.3 latency=32 link=yes maxlatency=8 mingnt=3 multicast=yes port=MII speed=100MB/s
resources: irq:23 ioport:cc00(size=256) memory:dfffd000-dfffd0ff
*-pci:1
description: Host bridge
product: P4M890 Host Bridge
physical id: 101
bus info: pci@0000:00:00.1
version: 00
width: 32 bits
clock: 33MHz
*-pci:2
physical id: 102
bus info: pci@0000:00:00.2
version: 00
width: 32 bits
clock: 33MHz
*-pci:3
physical id: 103
bus info: pci@0000:00:00.3
version: 00
width: 32 bits
clock: 33MHz
*-pci:4
physical id: 104
bus info: pci@0000:00:00.4
version: 00
width: 32 bits
clock: 33MHz
*-pci:5
product: P4M890 Security Device
physical id: 105
bus info: pci@0000:00:00.6
version: 00
width: 32 bits
clock: 33MHz
*-pci:6
physical id: 106
bus info: pci@0000:00:00.7
version: 00
width: 32 bits
clock: 33MHz
*-pci:7
product: VT8251 Ultra VLINK Controller
physical id: 107
bus info: pci@0000:00:11.7
version: 00
width: 32 bits
clock: 33MHz
configuration: latency=32
*-pci:8
product: VT8237A Host Bridge
physical id: 108
bus info: pci@0000:00:13.0
version: 00
width: 32 bits
clock: 33MHz
*-multimedia
description: Audio device
product: VT1708/A [Azalia HDAC] (VIA High Definition Audio Controller)
physical id: 1
bus info: pci@0000:80:01.0
version: 10
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=HDA Intel latency=0
resources: irq:17 memory:bfffc000-bfffffff
