GU 10 spot wiring
Stevie h
Oct 18, 2008
291
Liverpool
would you consider it bad practice to wire mains powered gu10 spots straight in and out in 1.0mm t+e ..... i normally use 12v spots so i wire in and out of penny jb and connect transformer , but have a load of mains spots to do and was thinking of wiring straight in+out with no jb,s
cheers
Ste
sparky999
Mar 24, 2008
405
I tend to wire into Jb and then into gu10 mains as then it is less strain on the main lighting wires, then instead of struggling get the 2 cables in there. Just my preferred method. :D
DonkeyDong
TEF Newbie
Mar 14, 2008
218
Agree...
T&E into a JB, then either 2 core or 3 core HR cable to the light (depending on light).
D.
Feb 27, 2008
11,034
would you consider it bad practice to wire mains powered gu10 spots straight in and out in 1.0mm t+e ..... i normally use 12v spots so i wire in and out of penny jb and connect transformer , but have a load of mains spots to do and was thinking of wiring straight in+out with no jb,scheers
Ste
I think the min size cable for downlights is 1.5mm in 17th edition will look through regs though.
Batty
Stevie h
Oct 18, 2008
291
Liverpool
I think the min size cable for downlights is 1.5mm in 17th edition will look through regs though.Batty
not heard of this before ........ let me know if you find anything in the regs .. i cant
cheers
Ste:)
