Hall & Stairs
Pipe
Jan 24, 2009
7
hi Everyone!
After trawling the web for an answer I thought this would be a good place to ask.
don't shoot me am a noob!Applaud Smiley
Ok i am renovating a house at present, house had a rewire few years back, but I wanted a double switch at bottom of stairs (hall light/landing light) and a single switch on landing.
As it sits,
DOWNSTAIRS
T&E (blue/brown) supply to hall rose - 2 brown & E, live & switched live to hall switch in COM and L2 (Working). 2 brown & E for landing in L2 and Com
strapped L1 (lights upsta)to L2 (lights downsta)
UPSTAIRS
T&E (blue/brown) supply to landing rose from hall
I have tried different ways to get correct lighting
plz could someone explain the proper way to do it
is it possible to also switch hall & landing on at landing switch, or am i being silly?
cheers in advance
Pipe :) ..::
cheers Special,
reading up still!! Guiness Drink
am i wrong in using twin brown cable for switching, I am one of the lucky few that dont need english regs (Northern Ireland), but still i want to do it right,
as I said in my previous post that is where i am at, is it wrong? cud you correct me?
Hello Pipe are you a plumber by any chance. We usually use three core and earth for two way switching but I have seen twin used on jobs but to me it gets a bit confusing.
Batty
You need three wires e.g. 3core+E
between each pair of two-way switches (excluding the earth wire!)
and two wires e.g. twin+E
from one end of the 2-way to the light fitting,
(assuming the power is looped at the light fitting.)
If you want FULL two way switching with
a double gang two-way switch in the hall
and another double gang two-way switch on the landing
There will be two 3-core+e between the switches,
and a Twin+E from landing light to upstairs switch.
and a Twin+E from hall light to downstairs switch.
So again assuming power is looped in and out at the ceiling roses
with all of the above cables pulled in you can have two completely independent pairs of two-way switching on on the downstairs & one on the upstairs light circuits.
heres some diagrams. excuse the bad quality,and they are also old colours
standard 2 way circuit, as done by most sparks
the alternative method of 2 way circuit
and for 2 way switching at both up and down
both lights will be connected to the same circuit
So if that circuit fuse blows the stairways could have no operational lighting at either top or bottom... :(
I Never do it like that:|
Avoid hazards & minimise inconvenience in the event of a fault. 314.1 (i) ?:|
I prefer Upstairs lights & downstairs lights. :) ;)
keep at least One light working either top or bottom
stop the old dear tripping down the stairs when the fuse blows. ;)
its just the way ive always wired it, avoid having 2 points of isolation at the switch
Thats no problem because a competent person should be opening up a switch.
Whereas it could be elderly person, maybe poor eyesight, got no light at all on stairway.
Its just the lazy way that stems back from the old days of
1 lights, 1 socket, 1 cooker & 1 imm' heater 4-way wylex cu IMHO.
no problems with multiple circuits in one switch box...
Thats why guidance always recommends a competent person, or if in doubt they can turn off all circuits at the CU.
Which in my experience a lot of customers do...
cuz they seem amazed I can work on the sockets with lights still on!!!!
and others still expect to be able to watch TV whilst you work on the socket its plugged into!
and keep the washing machine going & the bread machine while you modify the kitchen ring! ]:) :^O
we can ALWAYS arrange power for the kettle though! :) ;)
Cup of tea is the most important thing. I have a BT van with a stove in the back so if customer doesn't make one I make my own.
Batty
Cup of tea is the most important thing. I have a BT van with a stove in the back so if customer doesn't make one I make my own.Batty
Biscuits?
Cake?
tell us which lay-by you'll be parked in ..
and we'll all be round Monday 11:00am for tea & cakes:x;\ :D
