Forums
New posts
Search forums
What's new
New posts
New media
New media comments
Latest activity
Media
New media
New comments
Search media
Members
Current visitors
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Main Forums
Electrician Talk Forum
Have you installed a flush Fusebox before?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Luckyboy" data-source="post: 525344" data-attributes="member: 34072"><p>This is the issue, I think most flush mount consumer units are "made to fit" when they were first installed, so the hole in the wall will only fit the maximum size of the existing consumer unit.</p><p>The Fusebox I have bought is about 50mm wider than the original, I'm hoping they've left a bit of space on the sides, we'll see!</p></blockquote><p></p>
[QUOTE="Luckyboy, post: 525344, member: 34072"] This is the issue, I think most flush mount consumer units are "made to fit" when they were first installed, so the hole in the wall will only fit the maximum size of the existing consumer unit. The Fusebox I have bought is about 50mm wider than the original, I'm hoping they've left a bit of space on the sides, we'll see! [/QUOTE]
Insert quotes…
Verification
Post reply
Main Forums
