Points taken. However i think this could be a potentially dangerous situation where you gave wrong information. I noticed here and in other threads when challenged with regs you make snide comments and try to laugh it off, pot, kettle ?
In the case of a conduit being the cpc then you are not earthing the accessory, as you put it, but ensuring the earth continuity is at a socket outlet. Only today i visited a job where the decorator had all the sockets hanging off whilst stripping the walls with a electric steamer, the place was dripping. All the sockets were conduit fed with no cpc cable. This meant all the cables and leads supplying the metal steamer, drills, kettle, lead light etc were now unearthed. Now we all know that you should not remove a faceplate without isolating the supply, but try telling that to a decorator, plasterer or chippy. The other point to note is in the conduit cpc situation the screws holding the socket to the wall would be taking the full fault current of anything plugged in. When fed by Tw&e cable the fly lead is only 'bonding' the back-box in addition to the screws.
