paul b b
hello chaps,
ok, the heating system that is being installed has....
2x megaflows
1x 50-70kw boiler
under floor heating (wet)
it requires 4 pumps...
1 for each mega flow
2 for underfloor heating
1 for bathroom rads
all of the above apart from the manifolds are going to be in a cellar, i thought i would be easer to run a 10mm2 down to a second cu and run cables in conduit.
so here come some questions....
is it ok for the pumps to be run from FCU's? the megaflows and boiler will each have its own circuit.
how many cables can you run in a conduit?
can i take a 16mm2 earth from cu1 to cu2 and bond to oil/water from cu2?
now the complcated bit....
stats... should i run in 3core to be future proof as the plumber said only need 2 core?
he also wants a cut out incase the pressure gets to high. how do i do this?
i amgoing to use a honeywell box, i take it all stats are wired in from there?
the set up
how is this wired in? its made by centerstore
more to follow proberly...
2x megaflows
1x 50-70kw boiler
1 for bathroom rads
the set up
