help any ideas
frankie310581
Feb 16, 2011
41
Come across a siemens db it has 5sx21 mcbs in it and siemens say they don't make them any more but I need to fit rcbo's dose anyone now a make that will fit wylex don't
Got a siemens db and need to fit rcbo's to some ring mains but the db is fitted with mcbs 5sx21 from siemen spoke to them and they said don't do them any more dose any one now of a make that will fit wylex don't
No they dont, iv just checked. They matched with MEM but that was an old mcb too i think they got replaced by eaton.
Just found an Eaton, this matches and will fit, but the sprung din rail holder is on the opposite side( you may have to remove the bus bar), and the front sticks out a little further than siemens, ( this will only effect you if the door on the db is close.)
I think i fitted an MK old type rcbo too one a few years back if you can put a photo up of the box i may have one which is 32 amp if thats any help. I have tried it up against a GE rcbo and that looks like it may fit sure there must be other interchangeable ones too that may fit.
I have merged your duplicate threads, Frankie, as it only makes the forum untidy.
Mk is looking good buy the sounds of it
I have spoke to siemens and they said never made one but now the 17 th is here they are thinking of making one to fit the 5sx21 line which is obsolete as they are get about 50 calls a week how long the 17th been out lol will try a mk in the morning who are mk stockist
