- Nov 28, 2009
- 14,763
- 953
I am needing a dual rate electricity meter for my own use.
This is for my new build house. I want to monitor the electricity consumption of my Air Source Heat Pump and want to monitor how much it is using for heating, and separately how much is us using for hot water.
So I thought I can use an ordinary dual rate electricity meter. I have a 240V switched output that is only on when it's heating hot water so can use that (with a relay if needed ) to change rate on the meter.
So I started looking on ebay for cheap dual rate electricity meters. This is the only one I have found so far https://www.ebay.co.uk/itm/Electricity-Meter-Landis-Gyr-Single-Phase-2-Rate-Meter-100A-OFGEM/202431887856?epid=1627086932&hash=item2f21e179f0:g:7iQAAOSw0F9blVX0
But that is no good, that one has an inbuilt radio teleswitch so the rate switching is done at fixed times. I need the old school type where the rate switching is done by an external input.
Any ideas where I might get one?
