Hi all, I am changing my light switches but encounter a small concussion on my bathroom. The switch there is 1 gang two way (only used as 1 way) but it has a loop (neutral) connection on the switch too. The brand is Hager and they said on their web site “a unique LOOP terminal to allow neutral looping at the switch”. So the new switches are just an ordinary way two way without this loop(N) connection. My question is shall I just connect all the neutral in the box or shall I try to find switch like that which I probably won’t be able to as I already checked Amazon and all the metal switches don’t have this loop? Thank you for the help.
